TwinTurbo.NET: Nissan 300ZX forum - it's a good idea to check it before and after...
Paulym1111
on April 21, 2010 at 4:50 PM
Is it a MUST to check the timing after a TB change? (n/m)
posted by wolftg (DEN)
on April 21, 2010 at 03:42 PM
It helps to verify that your belt is on correctly because your timing shouldn't change if you didn't mess with the CAS. If the belt is installed incorrectly, the timing will be off. That being said....it's smart to do, but you don't have to.
wolftg (DEN)
15:42:56 04/21/10
it's a good idea to check it before and after... -
Paulym1111
16:50:43 04/21/10
Always check it after a timing belt change it is always
5280Z_nightstalker
01:35:05 04/22/10
